Projection Line Color in Python
I am trying to overwrite the projection line colors of structural framing elements with Python.
So far I came up with this;
clr.AddReference('RevitAPI')
view = IN[0]
elements = IN[1]
#color_from_node = IN[2]
element_id = [3]
color = Autodesk.Revit.DB.Color(255,255,255)
output = []
ogs = OverrideGraphicSettings().SetProjectionLineColor(color)
#for i in elements:
	#doc.ActiveView.SetElementOverrides((i.Id), ogs)
OUT = view, elements, color, ogs
However when I set the SetElemenOverrides in the for loop it asks for an ElementId instead of Element. So I type i.Id. However then Python says I am trying to pass an integer instead of an ElementId. Am I missing some step to tell Python it’s an ElementId instead of an integer?
You can convert the integer to an ElementId with doc.ActiveView.SetElementOverrides(ElementId(i.Id), ogs). You’ll need to start and end transaction as well.
Nice, worked like a charm! :grin:
For those who are interested, the code and result
view = IN[0]
elements = IN[1]
color = Autodesk.Revit.DB.Color(255,25,0)
output = []
for i in elements:
The result;
On a side note, I spent almost half the day googling and trying to understand the Python API. I can’t seem to find any documentation for this.
http://www.revitapidocs.com/
