Hoping someone can help, apologies for my terrible python…
I am trying to set graphic overrides in a view just for patterns, I am trying to do this through python, I have got it working, but only for a single element, could someone point out my mistake? Big thanks to Konrad @ Archi-Lab for the original code…
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def Unwrap(e):
return UnwrapElement(e)
def OverrideColorPattern(e, f):
gSettings = OverrideGraphicSettings()
gSettings.SetProjectionFillPatternId(f)
doc.ActiveView.SetElementOverrides(e.Id, gSettings)
return e
elements = ProcessList(Unwrap, IN[0])
fillPat = UnwrapElement(IN[1])
try:
errorReport = None
test = []
for i in elements:
test.append(OverrideColorPattern(i, fillPat))
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
#Assign your output to the OUT variable
if errorReport == None:
OUT = test
OUT = errorReport
You need to indent this line (with Tab)
Thanks Alban, I’ll have a go and let you know!
EDIT: That’s odd, my formatting didn’t copy and lost all the indents!
Hi Mark,
I edited your script :
# Import RevitAPI
clr.AddReference('RevitAPI')
import sys
def Unwrap(e):
return e
if isinstance(IN[1], list):
elements = list(Unwrap(IN[0]))
test = []
for i in elements:
test.append(OverrideColorPattern(i, fillPat.Id))
OUT = test
Thanks Alban,
Apologies but I didn’t explain myself very well…
What I should have said is… Say I have a list of 4 filled regions, I want to feed in a list of 4 different hatches.
Currently the script only works with a single hatch input.
Thank you for your time,
Mark
Why don’t you use a custom node and levels ?
Override FillPattern.dyf (4.2 KB)
Thanks Alban, that works great!
