Hello!
I’m very new to the Revit API. I am trying to get the color of line styles. It seems like something changed in R22 where the python script I used doesn’t work anymore. “i.LineColor” still works, but returns a System Object, not sure how to get the Red, Blue and Green values. I commented out the original line in the script below. Can anyone help? I would also greatly value some instruction on how to figure out how to find this information in the API.
Thanks!
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
# Start Transaction
lineStyle = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Lines)
lineStyleSubTypes = lineStyle.SubCategories
listNames = []
listRGB = []
lineWeight = []
listPattern = []
patname = []
listout = []
listpatid = []
for i in lineStyleSubTypes:
name = i.Name
#rgb = [i.LineColor.Red, i.LineColor.Green, i.LineColor.Blue]
rgb = i.LineColor
weight = i.GetLineWeight(GraphicsStyleType.Projection)
listNames.append(name)
listRGB.append(rgb)
lineWeight.append(weight)
id = i.GetLinePatternId(GraphicsStyleType.Projection)
pat = LinePatternElement.GetLinePattern(doc,id)
listPattern.append(pat)
listpatid.append(id)
try:
patname.append(pat.Name)
except:
patname.append("Solid")
style = i.GetGraphicsStyle(GraphicsStyleType.Projection)
listout.append(style)
# End Transaction
OUT = lineStyleSubTypes, listNames, listRGB, lineWeight, listPattern, patname, listpatid
