Project point on lines, points missing
I used “project point” on 2 curves with vectorZ axis , in order to place an adaptive component, but some point aren’t projected.
I’m sure that the two lines have the same x,y coordinates : these are projections in Z axis.
I don’t understand why !
Can anyone help me?
Can you post your dyn and a Revit file if one is necessary?
Hi
thank you
Membrane20171110-3.dyn (48.4 KB)
Can you try extracting the planes of the parameter/points on the curve and getting the intersecting geometry of the planes and the upper curve?
