Hello, guys I have a problem, I want to project points into a topography surface, and i think it’s happen some kind of bug,
well i have two sheets from excel with the coordinates of the points and the topography. And it’s ok to get into dynamo the points and the surface, but problem occurs in the node SURFACE.PROJECTINPUTONTO, look what happens:
here the code and as you can see all the points are in the Z axis of the projection of the surface:
I think the problem it’s the complex surface, I tested with a plane surface and went ok…
If someone could help me i would be very thankful
Thanks !
