I’m stuck on this script and honestly not sure if I’m even off to the right start. The goal is to create a Project Matrix sheet that shows the total values of all units on each floor and show the sum of the total values to get the overall sq ft of all units in the building. Here I am trying to find a way to get the total sq ft of the bedroom units on the first floor. This would be continued on the sheet to represent Construction Gross Area.
I do not want the values that sum up to get the total on each level to appear on the sheet, only the totals that are a result of these values and the total that is a result of totals on each level.
I understand it may be a bit confusing in wording but I cannot find a way to describe it without sharing a photo as I am not as peppered in Dynamo as of yet. If you do know the fix through the problem, please provide a brief walkthrough as I am trying to understand the logic to the best.
