Profile.CoordinateSystemByStation in revit dynamo
Halo ,
There is a component in civil3d dynamo “Profile.CoordinateSystemByStation”,
do it exist in revit dynamo ? or what plugin i need to download ? many thanks
Hi.
It only works in C3D but I assume that you should be able to transfer data between Civil and Revit if you have used it in Civil.
Check this conversation
@Brad.Chan1,
you can use this node “FeatureLine.Get_Point_CoordinateSystem_At_FeatutrLineByStation” from"" Brimohareb pak. or you can use civilconnection pak.
Both of these packages can access the Civil 3D COM API from Dynamo for Revit.
Note: this means you have to have Civil 3D and the file open.
