Hello everyone, I’m having a bit of an issue with reading and printing the content of an Excel file. The problem is that after running the code below, the values of each cell in the Excel file are being printed out on separate lines. However, I want to print the content exactly as it appears in the Excel file (with clear rows and columns). Please help me modify the code to achieve this. Thank you.
def ReadExcelFile(path):
# Instantiate the Excel Application
ex = Excel.ApplicationClass()
# Make it visible (optional)
ex.Visible = False
# Disable alerts
ex.DisplayAlerts = False
# Open workbook
workbook = ex.Workbooks.Open(path)
# Select the first worksheet
ws = workbook.Worksheets[1]
# Find the used range of cells
used_range = ws.UsedRange
# Get all values in the used range
all_data = used_range.Value2
# Close workbook and Excel application
workbook.Close(False)
ex.Quit()
# Release COM objects
Marshal.ReleaseComObject(used_range)
Marshal.ReleaseComObject(ws)
Marshal.ReleaseComObject(workbook)
Marshal.ReleaseComObject(ex)
return all_data
#Import Excel
# excelFilePath = forms.pick_excel_file()
excelFilePath = "C:\\Users\\PC\\Desktop\\Add Shared Param\\Add Shared Param.xlsx"
excelData = ReadExcelFile(excelFilePath)
for row in excelData:
print (row)
try this version
import sys
import System
clr.AddReference("System.Numerics")
from System import Array
from System.Runtime.InteropServices import Marshal
class ExcelEnum:
values Enum from API Interop Mircrosoft Doc
XlCellType_xlCellTypeLastCell = 11
ex = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("Excel.Application", True))
ex.Visible = False
# Disable alerts
# Open workbook
# get the last cell
last = ws.Cells.SpecialCells(ExcelEnum.XlCellType_xlCellTypeLastCell, System.Type.Missing)
rowCountF = last.Row
colCountF = last.Column
fullvalue = list(used_range.Value2)
#split list into sublist with number of colum
n = colCountF
datas = list(fullvalue[i:i+n] for i in range(0, len(fullvalue ), n))
ex.Quit()
return datas
#Import Excel
file_path = IN[0]
excelData = ReadExcelFile(file_path)
OUT = excelData
Alternatively, you can use:
- openpyxl or/and pandas (CPython3 Engine)
- Microsoft OpenXML (CPython3 or IronPython Engine)
Fantastic, it’s exactly what I want. Thank you very much.
