Alien
August 4, 2022, 4:29pm
#1
So I’m using Dynamo to fill in a ready prepared, formatted, Excel sheet.
I’d love to be able to get a PDF of the Excel sheet without having to open Excel and click, “print PDF”…
Now it seems pretty easy in Python 3… But sadly I only have Revit 2021 so am in IronPython.
I’ve tried several different ways but none work. I can’t even import win32com.Client so have had to work around that too.
Anyone help or is what I’m asking not possible and do I have to dream of the day I get a Revit upgrade?
Here’s some of the mess I’ve already tried:
here an example using interrop
import sys
import System
from System import Array
clr.AddReference('System.Windows.Forms')
import System.Windows.Forms
from System.Windows.Forms import SaveFileDialog, DialogResult
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
xlTypePDF = Excel.XlFixedFormatType.xlTypePDF
class Xls_Utils():
def __init__(self, path ,nameSheet = 1):
self._path = path
self._nameSheet = nameSheet
def ExportPdf(self):
ex = Excel.ApplicationClass()
ex.Visible = False
lst_xls = []
workbook = ex.Workbooks.Open(Filename=self._path, ReadOnly=True)
ws = workbook.Worksheets[self._nameSheet]
ws.Activate()
pages = ws.PageSetup.Pages.Count
print(pages)
saveXlsxFileDialog = SaveFileDialog()
saveXlsxFileDialog.Title = 'Name of PDF'
saveXlsxFileDialog.FileName = "{}_{}".format(System.IO.Path.GetFileNameWithoutExtension(self._path), str(self._nameSheet))
saveXlsxFileDialog.DefaultExt = "pdf"
saveXlsxFileDialog.Filter = "pdf files (*.pdf)|*.pdf|All files (*.*)|*.*"
saveXlsxFileDialog.RestoreDirectory = True
saveXlsxFileDialog.InitialDirectory = System.IO.Path.GetDirectoryName(self._path)
resultSaveAs = saveXlsxFileDialog.ShowDialog()
if resultSaveAs == DialogResult.OK:
fullpath = saveXlsxFileDialog.FileName
workbook.ExportAsFixedFormat(Type=xlTypePDF, FileName=fullpath, From=1, To=pages)
ex.Workbooks.Close()
ex.Quit()
#other proper way to make sure that you really closed and released all COM objects
Marshal.ReleaseComObject(workbook)
Marshal.ReleaseComObject(ex)
input = IN[0]
xls_sheetName = IN[1]
obj_xls = Xls_Utils(input, xls_sheetName)
obj_xls.ExportPdf()
which python3 package would you have used ?
Alien
August 5, 2022, 7:15am
#3
Thanks! I’ll see if I can get that to work - watch this space
I’ve not actually tried it in Python 3 but everything I read made it look really easy. The bit of code above was for Py3. Everything else said install win32com.Client
