I have a problem with the node Floor.ByOutlineTypeAndLevel when I try to create a floor by room. One or more floors are not created according to the models :
Any ideas ?
Alexis
What does the error state?
“The curves do not form a closed contiguous loop.
Parameter name: curve”
But I don’t know why…
You’ll have to explore the 10 curves which make up the polycurve. Note that you have 10 curves in the polycurve but only 8 bounding edges, so that is likely a good place to start.
Hi…
Which node contain … Rooms to PolyCurves node…
Can you tell me That node name…
Thank you
