Hello everyone,
I have some problems with creating new Shared Parameters with indicated GUID. Can you help me with this Dynamo Script please. It’s Excel file and this is shared code.
This script i found on this site and i just add guid on the ExternalDefenition. I checked this script and when we are create new SharedParameter creates new random GUID, but before i indicate a right GUID. I specify GUID in Excel file and add it in Definitions.
Python Script
import clr clr.AddReference('ProtoGeometry') from Autodesk.DesignScript.Geometry import * # Import DocumentManager and TransactionManager clr.AddReference("RevitServices") import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager # Import RevitAPI clr.AddReference("RevitAPI") import Autodesk from Autodesk.Revit.DB import * doc = DocumentManager.Instance.CurrentDBDocument uiapp = DocumentManager.Instance.CurrentUIApplication app = uiapp.Application from System.Collections.Generic import * from System import * # Import ToDSType(bool) extension method clr.AddReference("RevitNodes") import Revit clr.ImportExtensions(Revit.Elements) import System #The inputs to this node will be stored as a list in the IN variable. dataEnteringNode = IN _paramName = IN[0][0] _groupName = IN[0][1] _paramType = IN[1] _visible = IN[0][3] _category = IN[2] _paramGroup = IN[3] _instance = IN[0][6] _guids = IN[0][7] def ParamBindingExists(_doc, _paramName, _paramType): map = doc.ParameterBindings iterator = map.ForwardIterator() iterator.Reset() while iterator.MoveNext(): if iterator.Key != None and iterator.Key.Name == _paramName and iterator.Key.ParameterType == _paramType: paramExists = True break else: paramExists = False return paramExists def RemoveParamBinding(_doc, _paramName, _paramType): map = doc.ParameterBindings iterator = map.ForwardIterator() iterator.Reset() while iterator.MoveNext(): if iterator.Key != None and iterator.Key.Name == _paramName and iterator.Key.ParameterType == _paramType: definition = iterator.Key break message = None if definition != None: map.Remove(definition) message = "Success" return message def addParam(doc, _paramName, _visible, _instance, _groupName, _paramGroup,k): message = None if ParamBindingExists(doc, _paramName, _paramType): if not RemoveParamBinding(doc, _paramName, _paramType) == "Success": message = "Param Binding Not Removed Successfully" else: message = None group = file.Groups.get_Item(_groupName) if group == None: group = file.Groups.Create(_groupName) if group.Definitions.Contains(group.Definitions.Item[_paramName]): _def = group.Definitions.Item[_paramName] else: message = "creating!" _def = group.Definitions.Create(opt) param = doc.ParameterBindings.Insert(_def, bind, _paramGroup) return message #"Start" the transaction TransactionManager.Instance.EnsureInTransaction(doc) try: file = app.OpenSharedParameterFile() except: message = "No Shared Parameter file found." pass k=0 while k<_paramName.Count: builtInCategory = System.Enum.ToObject(BuiltInCategory, _category[k].Id) cats = app.Create.NewCategorySet() cats.Insert(doc.Settings.Categories.get_Item(builtInCategory)) if _instance[k]: bind = app.Create.NewInstanceBinding(cats) else: bind = app.Create.NewTypeBinding(cats) opt = ExternalDefinitionCreationOptions(_paramName[k], _paramType[k]) opt.Visible = _visible[k] opt.GUID = Guid(_guids[k]) if isinstance(_paramName[k], list): for i in _paramName[k]: message = addParam(doc, i, _visible[k], _instance[k], _groupName[k], _paramGroup[k], k) else: message = addParam(doc, _paramName[k], _visible[k], _instance[k], _groupName[k], _paramGroup[k],k) k=k+1 # "End" the transaction TransactionManager.Instance.TransactionTaskDone() #Assign your output to the OUT variable if message == None: OUT = message else: OUT = message
Thank you in advance.
Best, Denis
