I don’t know why but node doesn’t recognize the alignments, it considers them as empty. To clarify, I created these alignments with another script using node in Civil3DToolkit CreateAlignmentByPolyline and it works great.
What’s strange, manually created alignments in Civil node recognizes them.
Hi, check default layer in node input and layer of your alignment. Is it same in both cases?
Thanks a lot Lukas! That was exactly the reason. I created a new layer for the remaining alignments and it doesn’t recognize it then. As you mentioned, with the default layer everything works. Thank you
Hi, I cannot find the AlignmentExtensions.GetGeometry node in Civil3D. Could you please tell me how to find it?
Have you installed the Holy Trinity of packages for D4C3D, Arkance, Camber and Civil 3D Toolkit?
I follow your suggestions. It works well, thank you!
