Alignment.CreateOffsetAlignment Not Working
I am trying to run the node “Alignment.CreateOffsetAlignment”. However, I receive this error:
Any advice on how to resolve this would be appreciated. Thanks.
Which version of C3D do you use? Have you moved an existing graph into Civil 3D 2025?
Yes I am currently using the 2025.1 version.
This is the node in question. The inputs should be correct after checking multiple times.
Apologies as I cannot upload the file itself. Thank you
You need to use The Civil Nodes package v2025.1. Here it works fine:
If you have a different version of The Civil Nodes or Arkance Systems Node Library, you need to uninstall them.
It works after I uninstalled Arkane Systems. Thank you so much! Just one last thing: what version of Arkane System can I install that does not result in such error? Thank you once again.
The Arkance Systems Node Library is no longer maintained. You can use that library up to Civil 3D 2024. From Civil 3D 2025.1 you need the new The Civil Nodes package.
Noted. Thank you for the clarification
