Hello everyone, I was working on my algorithm on Dynamo, I had frozen some names so as not to slow down the program but when I restarted them, I get “null” in all nodes. I think the file is damaged because it doesn’t happen to me with other files. Could anyone help me?
I’ve already tried to do all of this.
moreover, it is only with this file that I get this error…
did you try rebuild your graph, node by node?
Try to Ctrl+C all and Ctrl+V into new file. Disable automatic run before paste!
The Watch node shows nothing instead of the null from All Elements of Category which makes me think you’re either in Manual run mode and haven’t run the graph or it’s locked up. Recreating the nodes (or the entire graph) should fix it.
Thank you so much, I hadn’t thought of that but it worked! You saved me!
Hello Mr Nick,
By that you mean that if the item is locked under revit, it wouldn’t show up in the list?
Sorry for the slight digression on your subject Mr. sa.salemme
Cordially
christian.stan
I mean the graph itself is generally locked up. That could be anything from stuck in a Revit command to a corrupt node. Either way, the graph is not running when it should be.
