I want to join two plaster walls to a base wall that already has defined window and door openings. However, when I try to make the connection, only one of the plaster walls correctly inherits the openings, with one of them missing. Image of algorithm attached
- Has anyone else faced a similar problem when trying to join plaster walls to a base wall with openings in Revit using Dynamo?
- What suggestions or recommendations could you provide to solve this issue with the inheritance of the openings?
- Is there any best practice or technique that can be applied to ensure the correct joining of the elements?
- Is there any alternative or different solution that I could explore to achieve the desired result?
I appreciate in advance any guidance or suggestions you can provide. I’m open to receiving your comments and advice.
