Problem in publishing custom nodes
Hi guys! For some reason, the “publish this custom node…” option is not available . I am using Dynamo 2.7.0 (the extension with Robot Structural Analysis). Does anyone know how to solve it?
Update: so, I believe it is something with the add in itself. I tried publish the node locally using the 2.3 version and it is working normally.
Are you launching Dynamo sandbox? This doesn’t allow publishing nodes - Try Dynamo for Revit, or Dynamo for Civil 3D.
Yep. When I used Dynamo for Revit it worked. thanks!
