Hey all,
is there a way I can print/save any string output of a node (information about my elements like parameter values in the project) to a .pdf file in a desired directory?
I know i can export these in excel using lists and stuff but i want a pdf instead of excel.
OR
can I convert an excel file to .pdf file using any node in a same script?
OR
can i integrate any string in views? i can print that view to .pdf later.
any of these can help me achieve my desired task
thanks in advance
I don’t know that you can go directly to PDF from Dynamo, but you could push back to Revit (an assumption here based on the topic you picked) and make a PDF of that.
Gather the string data
Make a new drafting view
Place a text note in the drafting view at the desired location
Confirm the bounding box dimension of the text note is less than your desired paper size
Easiest way would be to join the strings together before putting it on the view.
1st you can join them using separator as “\t” for tabs and the other time using “\n” to join all strings into one big text block.
wow… seems like it would work but i dont understand some of the nodes in here.
anyways im still not getting the exact thing.
have a look:
this is what i want:
Im using this graph. Din’t understand the x(0) code block so didnt use it may be thats the problem? if yes please help how to make that code block. thanks
Yup, I tried the exact same thing. It works well in the node preview but messes up the layout when you write it to Revit. ("-" used for preview. Same thing happens with a " ")
