Print pdf from Revit
Hello all,
I am new in Dynamo. I would like to ask if it is possible to print PDF from Revit. I have multiple sheets with different dimension. I use PDF Creator as pdf printer.
Thank you in advance!
Yes, it’s possible. There are tons of posts that already cover this. Try using those as a starting point and see where you get.
Thank you for your answer.
I print the prd from Revit but the size format is not correct. I get a message in Dynamo that it cannot use the print settings. Also after running dynamo in Revit in the print dialog box there is the message ’ print setting incompatible with printer ’
Capture|690x399
