Hello, I was wondering if it was possible to pull up the “Print Preview” before printing to PDF in Dynamo? Or does anyone have error proof way of printing Arch Sheets to PDF without having to worry if I am choosing the right paper size? What my current idea is, is to display the Title Block or sheet size, then have the ability to adjust the the Print settings before printing. My only fear is, the guys at the company I work for use the print preview to make sure the Sheet size/Paper size is correct. I realize it may be easier to just have them use the print button and adjust the settings from there but I wanted to try to find an easier way since this is part of a larger work flow. I am open to ideas, Thanks.
Related topics
Topic | Replies | Views | Activity | |
Batch PDF with multiple sheet sizes | 30 | 14078 | November 27, 2019 | |
How to print multiple PDFs with different paper size | 12 | 11099 | January 7, 2020 | |
Multiple format print using dynamo to PDF from Revit | 6 | 920 | November 10, 2021 | |
Print all different size sheets in order | 0 | 288 | October 4, 2019 | |
Print Sheet from Revit | 4 | 772 | November 1, 2020 |
