Print <in session> and set parameters
Hello Dynamo Friends :slight_smile:
I have a code to create a print setting with all parameters i want to set.
Now i want to print and set the parameters only in session without saving a print setting.
I use the code from @Konrad_K_Sobon, revised by @viktor_kuzev, @ Michael Park and @Alban_de_Chasteigner
I added the following parts:
get in session setting.
printSettings = FilteredElementCollector(doc).OfClass(PrintSetting)
for ps in printSettings:
	if ps.Name == "<in session>":
		printSetting = ps
and setting the orientation:
	# apply print setting
	try:
		printSetup = printManager.PrintSetup
		printSetup.CurrentPrintSetting = printSetting
		printManager.Apply()
		# set orientation
		printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PageOrientation = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PageOrientation.Landscape
But it does not work, my PageOrientation setting has no effect.
So how can i make changes to the printsetting before printing?
Happy about any advice! :slight_smile:
Full Code:
#Copyright(c) 2015, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Revised by viktor_kuzev
# Revised by Michael Park
# Revised by Alban de Chasteigner
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
import sys
sys.path.append(r"C:\Program Files (x86)\IronPython 2.7\Lib")
import os
filePath = ["C:\\Print\\Test.pdf"]
sheets = IN[0]
		printSetting = ps
printSettings = [printSetting]
printerName = "Microsoft Print to PDF"
pRange = System.Enum.Parse(Autodesk.Revit.DB.PrintRange, "Select")
combined = True
runIt = True
if isinstance(filePath, list):
	s_length = len(sheets)
	fp_length = len(filePath)
	if len(sheets) == len(filePath):
		pass
		filePath = filePath * (s_length / fp_length)
		if len(filePath) == len(sheets):
			pass
			OUT = "Filepaths and Sheets weren't the same length"
			exit()
elif isinstance(filePath, str):
	filePath = [filePath] * len(sheets)
if isinstance(sheets, list):
	viewSheets = []
	for i in sheets:
		viewSheets.append(UnwrapElement(i))
	viewSheets = UnwrapElement(sheets)
if isinstance(printSettings, list):
	printSetting = []
	for i in printSettings:
		printSetting.append(UnwrapElement(i))
	printSetting = UnwrapElement(printSettings)
printManager = doc.PrintManager
printManager.SelectNewPrintDriver(printerName)
	printSetup.CurrentPrintSetting = printSetting[0]
def PrintView(doc, sheet, pRange, printerName, combined, filePath, printSetting):
	# create view set
	viewSet = ViewSet()
	viewSet.Insert(sheet)
	# determine print range
	printManager.PrintRange = pRange
	# make new view set current
	viewSheetSetting = printManager.ViewSheetSetting
	viewSheetSetting.CurrentViewSheetSet.Views = viewSet
	# set printer
	# set combined and print to file
	if printManager.IsVirtual:
		printManager.CombinedFile = combined
		printManager.PrintToFile = True
		printManager.PrintToFile = False
	# set file path
	printManager.PrintToFileName = filePath
	# delete file. will prevent prompt for override existing
	if os.path.exists(filePath):
		os.remove(filePath)
	try:
		# set orientation
	except:
		pass
	# save settings and submit print
	viewSheetSetting.SaveAs("tempSetName")
	printManager.SubmitPrint()
	viewSheetSetting.Delete()
	return True
try:
	viewSets = FilteredElementCollector(doc).OfClass(ViewSheetSet)
	for i in viewSets:
		if i.Name == "tempSetName":
			doc.Delete(i.Id)
			TransactionManager.Instance.ForceCloseTransaction()
			continue
	errorReport = None
	message = "Success"
	if runIt:
		if isinstance(viewSheets, list) and isinstance(printSetting, list):
			for i, j, fp in zip(viewSheets, printSetting, filePath):
				PrintView(doc, i, pRange, printerName, combined, fp, j)
		elif isinstance(viewSheets, list) and not isinstance(printSetting, list):
			for i, fp in zip(viewSheets, filePath):
				PrintView(doc, i, pRange, printerName, combined, fp, printSetting)
		elif not isinstance(viewSheets, list) and not isinstance(printSetting, list):
			PrintView(doc, viewSheets, pRange, printerName, combined, filePath[0], printSetting)
		message = "Set RunIt to True"
except:
	# if error accurs anywhere in the process catch it
	import traceback
	errorReport = traceback.format_exc()
# Assign your output to the OUT variable
if errorReport is None:
	OUT = message
	OUT = errorReport
edit:
I still could create and delete a tempPrintSetting if i find no other method, just wondering why my method doesn´t work.
It works now by creating and deleting print settings.
# Import RevitAPI
import System
import sys
import os
def CreatePrintSetting():
	for size in printManager.PaperSizes:
		if size.Name == "A4":
			A4 = size
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PaperSize = A4
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ZoomType = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ZoomType.Zoom
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.Zoom = 100
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ZoomType = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ZoomType.FitToPage
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HiddenLineViews = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HiddenLineViews.VectorProcessing
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HiddenLineViews = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HiddenLineViews.RasterProcessing
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PageOrientation = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PageOrientation.Portrait
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ViewLinksinBlue = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HideReforWorkPlanes = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HideUnreferencedViewTags = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MaskCoincidentLines = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HideScopeBoxes = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.HideCropBoundaries = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ReplaceHalftoneWithThinLines = True
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ColorDepth = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ColorDepth.Color
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ColorDepth = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ColorDepth.GrayScale
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ColorDepth = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.ColorDepth.BlackLine
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality.High
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality.Low
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality.Medium
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.RasterQuality.Presentation
	printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PaperPlacement = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PaperPlacement.Center
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PaperPlacement = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.PaperPlacement.LowerLeft
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MarginType = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MarginType.NoMargin
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MarginType = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MarginType.PrinterLimit
	#printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MarginType = printManager.PrintSetup.CurrentPrintSetting.PrintParameters.MarginType.UserDefined
	printManager.PrintSetup.SaveAs("tempPrintSetting")
	# create view set
	viewSet = ViewSet()
	# set printer
	# set file path
		os.remove(filePath)
	try:
		# set orientation
	except:
		pass
	return True
sheets = IN[0]
CreatePrintSetting = CreatePrintSetting()
#	if ps.Name == "<in session>":
	if ps.Name == "tempPrintSetting":
		printSetting = ps
combined = True
runIt = True
		pass
			pass
			exit()
	viewSheets = []
	for i in sheets:
	printSetting = []
try:
	for i in viewSets:
			doc.Delete(i.Id)
			continue
	errorReport = None
	message = "Success"
	if runIt:
except:
	import traceback
for i in printSetting:
	doc.Delete(i.Id)
	OUT = message
	OUT = errorReport
Nice work!
This would have come in handy for my PDF graph and my firm’s 60 different paper sizes…
Thank the lor’s of Revit for creating the PDF Export function…
I added some code.
Get PaperSizes for every sheet (from title block name):
PaperSizeStrings = []
PaperSizeElements=[]
for i in sheets:
	sheet = UnwrapElement(i) #the internalelement equivalent
	firstTTBL = FilteredElementCollector(doc,sheet.Id).OfCategory(BuiltInCategory.OST_TitleBlocks).FirstElement()
	for x in ["A0","A1","A2","A3","A4"]:
		if x in firstTTBL.Name:
			size = x
			PaperSizeStrings.append(x)
for i in PaperSizeStrings:
	for x in printManager.PaperSizes:
		if i == x.Name:
			PaperSize = x
	PaperSizeElements.append(PaperSize)
And create a printsetting for every sheet:
	outlist = []
	for size, string in zip(PaperSizeElements,PaperSizeStrings):
		tempPrintSettingName = "tempPrintSetting_" + string
		PrintParameters = printManager.PrintSetup.CurrentPrintSetting.PrintParameters
also cleaned up the setting parameters a little bit.
Full:
# Import RevitAPI
import System
import sys
import os
	outlist = []
		PrintParameters.PaperSize = size
		PrintParameters.ZoomType = PrintParameters.ZoomType.Zoom
		#PrintParameters.ZoomType = PrintParameters.ZoomType.FitToPage
		PrintParameters.HiddenLineViews = PrintParameters.HiddenLineViews.VectorProcessing
		#PrintParameters.HiddenLineViews = PrintParameters.HiddenLineViews.RasterProcessing
		PrintParameters.PageOrientation = PrintParameters.PageOrientation.Landscape
		#PrintParameters.PageOrientation = PrintParameters.PageOrientation.Portrait
		PrintParameters.ColorDepth = PrintParameters.ColorDepth.Color
		#PrintParameters.ColorDepth = PrintParameters.ColorDepth.GrayScale
		#PrintParameters.ColorDepth = PrintParameters.ColorDepth.BlackLine
		PrintParameters.RasterQuality = PrintParameters.RasterQuality.High
		#PrintParameters.RasterQuality = PrintParameters.RasterQuality.Low
		#PrintParameters.RasterQuality = PrintParameters.RasterQuality.Medium
		#PrintParameters.RasterQuality = PrintParameters.RasterQuality.Presentation
		PrintParameters.PaperPlacement = PrintParameters.PaperPlacement.Center
		#PrintParameters.PaperPlacement = PrintParameters.PaperPlacement.LowerLeft
		#PrintParameters.MarginType = PrintParameters.MarginType.NoMargin
		#PrintParameters.MarginType = PrintParameters.MarginType.PrinterLimit
		#PrintParameters.MarginType = PrintParameters.MarginType.UserDefined
		printManager.PrintSetup.SaveAs(tempPrintSettingName)
		outlist.append(tempPrintSettingName)
	return outlist
	# create view set
	viewSet = ViewSet()
	# set printer
	# set file path
		os.remove(filePath)
	try:
		# set orientation
	except:
		pass
	return True
sheets = IN[0]
for i in sheets:
			size = x
		if i == x.Name:
			PaperSize = x
CreatePrintSettings = CreatePrintSetting()
printSettings = []
allPrintSettings = FilteredElementCollector(doc).OfClass(PrintSetting)
for cps in CreatePrintSettings:
	for aps in allPrintSettings:
		if aps.Name == cps:
			printSetting = aps
	printSettings.append(printSetting)
combined = True
runIt = True
		pass
			pass
			exit()
	viewSheets = []
	for i in sheets:
	printSetting = []
try:
	for i in viewSets:
			doc.Delete(i.Id)
			continue
	errorReport = None
	message = "Success"
	if runIt:
except:
	import traceback
	doc.Delete(i.Id)
	OUT = message
	OUT = errorReport
