Coding challenge.. PLS HELP
So I wrote a script that loops changes in parameters on sheets and title blocks and printing them. The problem is it prints without any errors and the parameters look fine. but the parameter graphics don’t get updated
see it used to work. but all of a sudden it stopped working.
here is the code( the major piece of it)
for BuildingNo,bldgDirection,Angle in zip(BuildingNoValue, DirectionValue, AngleValue):
	theSheet[0].SetParameterByName("BLDG. NO.", BuildingNo)
	theSheet[0].SetParameterByName("UNIT ORIENTATION", bldgDirection)
	elem = UnwrapElement(TitleBlock[0])
	parameter = elem.LookupParameter("NR - ANGLE")
	debuglist.append(parameter)
	parameter.Set(Angle)
	y = TitleBlock[0].GetParameterValueByName("NR - ANGLE")
	debuglist.append(y)
	PrintView(doc,theSheet,pRange, printerName, combined, filePath,printSetting)
OUT = debuglist
Think you’ll need to commit the transaction before you print. Swap the 3rd to last line with the second to last line and see if that works.
excuse me it was like that before. still no luck. i will update the script in question. thanks!
Can you post the full code including the print view definition? Need to see which api methods are in play, as my guess is a doc regenerate is needed but can’t know without the context.
HERE IS THE FULL CODE
import sys
import time
dataEnteringNode = IN
# Place your code below this line
# Import Element wrapper extension methods
# Import geometry conversion extension methods
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
from Revit.Elements import*
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
#The inputs to this node will be stored as a list in the IN variable.
sheets = IN[0]
pRange = System.Enum.Parse(Autodesk.Revit.DB.PrintRange, IN[1])
combined = IN[2]
printerName = IN[3]
printSetting = IN[4]
filePath = IN[5]
runIt = False
theSheet = IN[7]
parameterName = IN[8]
BuildingNoValue = IN[9]
AngleValue = IN[10]
DirectionValue = IN[11]
TitleBlock = IN[12]
titleparam = IN[13]
if isinstance(sheets, list):
	viewSheets = []
	for i in sheets:
		viewSheets.append(UnwrapElement(i))
	viewSheets = UnwrapElement(sheets)
def PrintView(doc, sheet, pRange, printerName, combined, filePath, printSetting):
	# create view set
	#viewSet = ViewSet()
	#viewSet.Insert(sheet)
	# determine print range
	printManager = doc.PrintManager
	printManager.PrintRange = pRange
	printManager.Apply()
	# make new view set current
	viewSheetSetting = printManager.ViewSheetSetting
	#viewSheetSetting.CurrentViewSheetSet.Views = viewSet
	# set printer
	printManager.SelectNewPrintDriver("PDF Writer - bioPDF")
	# set combined and print to file
	if printManager.IsVirtual:
		printManager.CombinedFile = combined
		printManager.PrintToFile = True
		printManager.PrintToFile = False
	# set file path
	#printManager.PrintToFileName = filePath
	# apply print setting
	try:
		printSetup = printManager.PrintSetup
		printSetup.CurrentPrintSetting = printSetting
	except:
		pass
	# save settings and submit print
	viewSheetSetting.SaveAs("tempSetName")
	printManager.SubmitPrint()
	viewSheetSetting.Delete()
	return True
debuglist = []
	theSheet.SetParameterByName("BLDG. NO.", str(BuildingNo))
	theSheet.SetParameterByName("UNIT ORIENTATION", str(bldgDirection))
	elem = UnwrapElement(TitleBlock)
	parameter.Set(int(Angle))
	y = TitleBlock.GetParameterValueByName("NR - ANGLE")
	debuglist.append(y)
	PrintView(doc,IN[7],pRange, printerName, combined, filePath,printSetting)
OUT = debuglist
try to regenerate the current document with doc.Regenerate() during the process
# some code
    debuglist.append(y)
    doc.Regenerate() ## <- Add Here
# rest of code
it works for another file but not for a similar one with the same parameters
try to call the PrintView function outside the loop at the end
# some code
    debuglist.append(y)
doc.Regenerate()
# rest of code
your code is difficult to understand:
  • some input variables are unused
  • content of input lists is unknown (empty list?)
  • why you use a for loop to set parameters for one sheet?
  • does your input titleblock correspond to the input theSheet?
the best is to share an example of file (if possible) too
