Hi All,
Apologies for my inability to code…
I’m trying to automatically print sheets to the correct paper size.
So I need to write a script which takes a list of strings, looks for particular phrases (A0, A1, A3) and applies a print setting accordingly.
I’ve read as many tutorials as I can and tried to put together a code which works, but unfortunately I’ve run out of knowledge and places to look…!
Any assistance would be gratefully received.
Thanks,
Mark
# Import Element wrapper extension methods
# Import geometry conversion extension methods
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
lst = IN[0]
printerOne = IN[1]
printerTwo = IN[2]
printerThree = IN[3]
result = []
if 'A01' in str(lst):
printSetup = printManager.PrintSetup
printSetup.CurrentPrintSetting = printerOne
printManager.Apply()
elif 'A1' in str(lst):
printSetup.CurrentPrintSetting = printerTwo
printSetup.CurrentPrintSetting = printerThree
OUT = Answer
