How to show parameters under Electrical - Circuiting
Is there anyone who knows what node I should use to access parameters under Electrical - Circuiting for panel schedules?
Hi @ffarmani
Try using Element.ElementType node to get the type and then use Element.Parameters to get its type parametets.
Hi @Kulkul, I tried to get the parameters but these ones are not there. Not sure if I’m doing it right?
Connect ElementType to Element.parameters:
Thank you @Kulkul. You are the best.
