I’m using an excel file to create sheet(name and numero) with the “Sheet.ByNameNumberTitleBlockAndView” node. My first attempt was to use the excel to name the existing view for the node, but it wasn’t working.
So I’m using now the “Get Views from View Set” like this : But as you can see, it doesn’t work. The error : Avertissement:Un ou plusieurs des types d’entrées ne correspondent pas. Impossible de trouver une version de ByNameNumberTitleBlockAndView qui accepte les arguments de type (__array,__array,Revit.Elements.FamilyType,__array) Isn’t it possible to give the node multiple view ? or Am I using it the wrong way ?
