Hello, I am trying to get all the room names and numbers automatically populated into the mechanical equipment that I have in that room, but dynamo keeps crashing on me. I need to check the mechanical equipment for an intersection with the rooms because some of the mechanical equipment is outside of its room, however, I did add room calculation points, so I should be ok?? I am using a geometry does intersect but it keeps crashing. What am I doing wrong? Thanks!
I am not on my system right now but shouldn’t this already work inside revit if you activate the room location point in your mechanical families and then create a schedule with the room info?
not in linked models (rooms), no.
