Polysurface by loft. Why can't I see it properly in Revit?
I’m using a fairly basic solution using polysurface.byloft node to generate a surface between 3 curves ( two arcs and a line actually).
I can see the curves created in the revit window and the is a very slight masking where the surface must be but I cannot select it or make a roof from mass from it’s surface. Here’s an image of the curves. Do I need to perform more actions on the polysurface to turn it into a revit recognisable surface in which to make a roof? Tutorial videos I’ve been watching don’t seem to have to do this. I also never see anything in the Dynamo 3D viewer. Why is that?
Thanks!
Roof script.dyn (13.9 KB)
Dynamo geometry is not Revit Geometry, you need to take the Surfaces/Solids into a Massing family or in-place geometry in Revit to do what you describe.
Ok Thanks @Bjorn_Keulemans1
I’m trying now to use the Fmaily.Instance.bygeometry node to create a generic family that i can then turn into a roof via it’s surface. But I don’t think my polysurface is working. Does this make any sense?
Ok I’ve managed to get it to work now. The FamilyInstance.ByGeometry node code was referring to redundant terms in the api so I changed them to the newer ones. I’ve attached a copy of the code which i updated and can confirm works, if anyone wishes to use this in REVIT 2020 or later. Credit to this forum post for the solution FamilyInstance.ByGeometry not working in Revit 2022 - #15 by Thomas3
#Copyright(c) 2016, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
import System
from itertools import repeat
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
import sys
sys.path.append('%s\IronPython 2.7\Lib' %pf_path)
import traceback
from Autodesk.DesignScript.Geometry import Point as DynPoint
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Structure import StructuralType
def tolist(obj1):
	if hasattr(obj1,'__iter__'): return obj1
	else: return [obj1]
def PadLists(lists):
	len1 = len(lists[0])
	for i in xrange(1,len(lists)):
		len2 = len(lists[i])
		if len2 == len1 : continue
		elif len2 > len1: lists[i] = lists[i][:len1]
		else : lists[i].extend(repeat(lists[i][-1],len1 - len2))
	return lists
class FamOpt1(IFamilyLoadOptions):
	def __init__(self):
		pass
	def OnFamilyFound(self,familyInUse, overwriteParameterValues):
		return True
	def OnSharedFamilyFound(self,familyInUse, source, overwriteParameterValues):
		return True
geom = tolist(IN[0])
fam_path = IN[1]
names = tolist(IN[2])
category = tolist(IN[3])
material = tolist(IN[4])
isVoid = tolist(IN[5])
subcat = tolist(IN[6])
#units = doc.GetUnits().GetFormatOptions(UnitType.UT_Length).DisplayUnits
#factor = UnitUtils.ConvertToInternalUnits(1,units)
units = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
acceptable_views = ('ThreeD', 'FloorPlan', 'EngineeringPlan', 'CeilingPlan', 'Elevation', 'Section')
origin = XYZ.Zero
str_typ = StructuralType.NonStructural
t1 = TransactionManager.Instance
temp_path = System.IO.Path.GetTempPath()
invalid_chars = System.IO.Path.GetInvalidFileNameChars()
satOpt = SATImportOptions()
satOpt.Placement = ImportPlacement.Origin
#satOpt.Unit = ImportUnit.Foot
satOpt.Unit = ImportUnit.Custom
satOpt.CustomScale = 1/3.280839895
opt1 = Options()
opt1.ComputeReferences = True
SaveAsOpt = SaveAsOptions()
SaveAsOpt.OverwriteExistingFile = True
def NewForm_background(s1, name1, cat1, isVoid1, mat1, subcat1):
	try:
		enable_mat = False if mat1 is None else True
		enable_subcat = False if subcat1 is None else True
		if any( (c in name1 for c in invalid_chars) ):
			raise Exception('Family name contains invalid characters')
		TransactionManager.ForceCloseTransaction(t1)
		famdoc = doc.Application.NewFamilyDocument(fam_path)
		sat_path = '%s%s.sat' % (temp_path, name1)
		if factor != 1:
			s1 = s1.Scale(factor)
		vec1 = Vector.ByTwoPoints(BoundingBox.ByGeometry(s1).MinPoint, DynPoint.Origin())
		s1 = s1.Translate(vec1)
		sat1 = Geometry.ExportToSAT(s1, sat_path)
		view_fec = FilteredElementCollector(famdoc).OfClass(View)
		view1 = None
		for v in view_fec:
			if str(v.ViewType) in acceptable_views and not v.IsTemplate:
				view1 = v
				break
		t1.EnsureInTransaction(famdoc)
		satId = famdoc.Import(sat1, satOpt, view1)
		el1 = famdoc.GetElement(satId)
		geom1 = el1.get_Geometry(opt1)
		enum = geom1.GetEnumerator()
		enum.MoveNext()
		geom2 = enum.Current.GetInstanceGeometry()
		enum2 = geom2.GetEnumerator()
		enum2.MoveNext()
		s1 = enum2.Current
		famdoc.Delete(satId)
		System.IO.File.Delete(sat_path)
		save_path = '%s%s.rfa' % (temp_path, name1)
		try: #set the category
			fam_cat = famdoc.Settings.Categories.get_Item(cat1.Name)
			famdoc.OwnerFamily.FamilyCategory = fam_cat
		except: pass
		s2 = FreeFormElement.Create(famdoc,s1)
		if isVoid1:
			void_par = s2.get_Parameter(BuiltInParameter.ELEMENT_IS_CUTTING).Set(1)
			void_par2 = famdoc.OwnerFamily.get_Parameter(BuiltInParameter.FAMILY_ALLOW_CUT_WITH_VOIDS).Set(1)
		else: #voids do not have a material values or a sub-cateogry
			if enable_mat:
				try:
					mat_fec = FilteredElementCollector(famdoc).OfClass(Material)
					for m in mat_fec:
						if m.Name == mat1:
							fam_mat = m
							break
					mat_par = s2.get_Parameter(BuiltInParameter.MATERIAL_ID_PARAM).Set(fam_mat.Id)
				except: pass
			if enable_subcat: #create and assign the sub-category:
				try:
					current_fam_cat = famdoc.OwnerFamily.FamilyCategory
					fam_cat_subs = current_fam_cat.SubCategories
					if fam_cat_subs.Contains(subcat1):
						new_subcat = fam_cat_subs[subcat1]
						new_subcat = famdoc.Settings.Categories.NewSubcategory(current_fam_cat, subcat1)
					s2.Subcategory = new_subcat
				except: pass
		famdoc.SaveAs(save_path, SaveAsOpt)
		family1 = famdoc.LoadFamily(doc, FamOpt1() )
		famdoc.Close(False)
		System.IO.File.Delete(save_path)
		symbols = family1.GetFamilySymbolIds().GetEnumerator()
		symbols.MoveNext()
		symbol1 = doc.GetElement(symbols.Current)
		t1.EnsureInTransaction(doc)
		if not symbol1.IsActive: symbol1.Activate()
		inst1 = doc.Create.NewFamilyInstance(origin, symbol1, str_typ)
		ElementTransformUtils.MoveElement(doc,inst1.Id, vec1.Reverse().ToXyz() )
		return inst1.ToDSType(False), family1.ToDSType(False)
	except:
		return traceback.format_exc(),''
if len(geom) == len(names) == len(category) == len(isVoid) == len(material) == len(subcat):
	return1 = map(NewForm_background, geom, names, category, isVoid, material, subcat)
elif len(geom) == len(names):
	padded = PadLists([geom, category, isVoid, material,subcat])
	p_category, p_isVoid, p_material, p_subcat = padded[1], padded[2], padded[3], padded[4]
	return1 = map(NewForm_background, geom, names, p_category, p_isVoid, p_material, p_subcat)
else : return1 = [('Make sure that each geometry\nobject has a unique family name.', '')]
OUT = [i[0] for i in return1], [i[1] for i in return1]
satOpt.Dispose()
opt1.Dispose()
SaveAsOpt.Dispose()
