I am looking to create the barrier face of a vehicle restraint system barrier. I am just stuck on joining up 5 points vertically to create a basic face which I will then loft to suit.
Please see screenshot below, I am expecting “PolyCurve(NumberOfCurves = 4)” from the PolyCurves.ByPoints since there are 4 lines between the 5 points. Would you be able to tell me if I am missing something out here?
I’m seeing 4 curves as expected. What version of C3D and Dynamo are you using ?
Works in 1.3 and 2.10 for me… assuming everything in between as well. Can you post the graph @Conor.Fraser and a screenshot of your Dynamo’s Help > About?
@Conor.Fraser Do you have your Geometry Working range set to medium?
Hi All,
Thanks for your replies. I am using Civil 3D 2020 and Dynamo version shown in screenshot below.
Ive got the geometry scalling set to extra large, is this likely the issue?
Never change it from Medium, ignore the warning messages
Thats been the issue. Thank you for the clarification.
