Poly curves fail to join and to be closed
Hi~
The problem is described as the title and presented by the image. BTW I couldn’t find the grimshaw package from the archi-lab. maybe could anyone attach the links, thank you. I really want to try out the group curve node.
Try this…
Select all lines in Revit with one selection window.
However, works only if every curve selected is part of a closed loop.
File: CurveLoops.dyn
20160509-5
Hi Chen,
You can also try using custom node “Group Curves” from archi-lab Package.
I have published Curve.SuperJoin v0.1.5 which will automatically group and join the curves. You can search and try
Thank you guys so much , I definitely will give it a try soon.
