Hi all
Can/will any tell what I/we do wrong in this case.
We find that if you place an object fx. a wall with start point 0,0,0 and use element location from clockwork to present the curve endpoint, then everything is fine. But to separate the coordinates I like to use point.X and point.Y nodes. All the 0.000 results are now shown as mathematical numbers??
The issue is only shown for 0.000 results; any other results works fine.
Hope you will help solving the confused result.
/Palle
