I opened up an old graph on mine and for some reason element.location+ isnt working any more.
Any ideas on why this is giving me an error?
I have no idea, but since you are just using this script to extract pipe curves, maybe you can work around this node?
Maybe reinstalling the Package helps.
I also have facing problem with Element.Location+ package, then I tried DynaMEP package and it is working perfectly but the main problem is this package considered project base point as a (0,0,0) location. When I specify the coordinate with a certain value but the result shows me (x,y,z) value calculating from zero (0,0,0) point. Is there any solution regarding this issue??
