Point boundary condition on analytical column node
I have a problem with adding point boundary condition to analytical column node, I have Python script:
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
elt=UnwrapElement(IN[0])
R=float(IN[1])
bc = []
# Start Transaction
for e in elt:
	ref = Autodesk.Revit.DB.Reference(e)
	s=Autodesk.Revit.DB.Structure.TranslationRotationValue.Fixed
	a=doc.Create.NewPointBoundaryConditions(ref,s,R,s,R,s,R,s,R,s,R,s,R)
	bc.append(a)
# End Transaction
OUT = bc
I am using “Select elements” for selecting all nodes which I want to have boundary condition on and python script shows: Parameter name: Boundary Condition is already created on the selected reference. It is not allow to duplicate Boundary Conditions.
I have no boundary condition in project… Do you know where is the problem?
I think this line is wrong, but I found a topic: https://forum.dynamobim.com/t/point-boundary-condition-hosted/35533/2 and there one user wrote that this is working for him and another has the same problem… I tested for another project and in another ver of dynamo, still nothing. I have more than hundred columns to insert boundary condition on… Here is from RevitApi: RevitApi
