Point boundary condition - hosted
Hi Damiano,
I was exactly looking for the same thing as you and I tried the same change as you did. I realised then that the first input of the API function for Point boundary need to be a “Reference” (and cannot be an “Element” as it could be for line boundary function). So I tried to change the first input into an element and it seems to work!
(I used it for Analytical Isolated Foundation though, not for Analytical Columns but I guess it should work as well)
However I still have no idea what a “Reference” is and if someone could help me explaining what it is exactly it would be great :slight_smile:
Thanks,
Arthur
# Import RevitAPI
clr.AddReference("RevitAPI")
elt=UnwrapElement(IN[0])
R=float(IN[1])
bc = []
# Start Transaction
for e in elt:
	ref = Autodesk.Revit.DB.Reference(e)
	s=Autodesk.Revit.DB.Structure.TranslationRotationValue.Fixed
	a=doc.Create.NewPointBoundaryConditions(ref,s,R,s,R,s,R,s,R,s,R,s,R)
	bc.append(a)
# End Transaction
OUT = bc
