Hi there,
I’m in the same position at the moment, did you find a solution?
Basically i need to create point boundary condition to the top (end analytical node) of a selection of columns via dynamo.
I’ve only found a node called “createlineboundarycondition” in Dynamo from the package “Steamnodes”, i can see the python script to create the line load inside the node, but i don’t know how to edit to make it work for the point boundary.
Any help would be much appreciated, thanks
Here the script from steamnodes:
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
Import ToDSType(bool) extension method
Import geometry conversion extension methods
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
elt=UnwrapElement(IN[0])
R=float(IN[1])
bc=
Start Transaction
for e in elt:
s=Autodesk.Revit.DB.Structure.TranslationRotationValue.Fixed
a=doc.Create.NewLineBoundaryConditions(e,s,R,s,R,s,R,s,R)
bc.append(a)
End Transaction
OUT =bc
