Please give me some solution to change revit schedule row height by Dynamo
When I create schedule from revit model . The table cannot adjust row height , It can be adjust column width only . If anyone can be use dynamo change that . Please give me some solution to change revit schedule row height by Dynamo .
I don’t believe you can- the Revit schedule ‘appearance’ properties allow you to change the font, but that is about it.
The best option is probably to export the data, then dress it up in your tool of choice- such as Excel, Access or proper reporting tools. Dynamo can help in the exporting of data.
Andrew
Thanks Andrew !
