Is it possible to change schedule appearance settings with Dynamo?
Specifically “Blank row before data”?
i have a same problem.
I am not sure if you can change this, but also have you thought about creating a view template for the schedule then apply that to all new schedules?
This will be quicker than trying to figure out how to change this on all views.
hello
currently, this property is not accessible via Revit API
Thank you, just using a view template is indeed a simple and elegant solution.
Tank you for confirming this.
is it available in any newer Revit versions?
I don’t think so, to check
still not available
ps archilab have some few nodes as well for appeance and schedules…but long time ago i have tried these…but that thing isnt a part of these nodes if i remember right…any way what i find hardest when create the nodes it was the difference in appeance in schedule itself vs schedules on sheets…seems to very different things…however guess we always can go the good old template way ![]()
We are still in R26, so might be possible in R27 as you said.
yes maybe, havent tried, but i am not so optimistic here but hope you are right ![]()
Looks like it’s not added to 2027 either. Best to start an API wishlist item on the Revit API forum so it’s surfaced as a user request.
right just check as well…no luck
