Hello Dynamites, i wanna place objects along a path an align them to the path. But my Code dose not work . I hope you can help me
Hello @Jan-Julius.Hansen and welcome try something here…
Amigo @Jan-Julius.Hansen buenas, the solution of @sovitek is an elegant one, try use Curve.CoordinateSystematsegmentLength may be works too, check this post
Yes @gilberto.arechigaiba …could definitly be made by a coordinatesystem as well
@sovitek, I too am having an issue of aligning and rotating an element to a curve. In my case, I’m trying to insert a Generic Model representing Fireproofing around a Beam. I find that the recommended Solid.ThinShell node breaks when Structural Connections are added to the framing members. I am able to get my diagram to grab the curve of the beam, set a point midway, and align the vector. As you can see, I’m unable to achieve true alignment on two of the beams that are not aligned x and y. Am I missing something in my diagram?
@sovitek Here is the result in Revit.!
image|690x337
Hello @billk.vjss and welcome here…Not sure what you ask about,but please make a new topic as i dont see any connection with the original…
