Placing Keynote Tags to Multiple Elements (Tag All)
I am trying to get Dynamo to give Keynote Tags a similar functionality to the Tag All tool in Revit.
I am utilising Konrad’s “Create Annotation Tag” node but it doesn’t seem to work with Keynote Tags?
I don’t think that it is possible to access the keynote creation through the API, so I was hoping that somebody may have a creative solution to the problem?
In my graph I am utilising a couple of Springs nodes to allow me to select multiple elements rather that gathering everything on the view.
Thanks for any help.
As far as I know, you can only place category and material tags through the API:
http://www.revitapidocs.com/2017/1e087d7f-aa78-b319-afc6-2d9019d3646d.htm
Maybe you can use detail items instead of keynotes?
Just as I thought.
Unfortunately it has to be the Keynote as it has wider implications. I was thinking that a possible work-around is to copy an existing keynote tag and place it at the instances on the family and then re-associate the value to the object.
Hopefully this won’t break the Keynote link…
I know I might be fighting a losing battle but I have managed to get to a point where I have isolated a Keynote Tag on the current view, found a basepoint and found new placement points. I was hopping that I might be able to just copy the tag to new locations and then reassociate the values? I am hoping that someone may have an idea on how to copy the tag? (or tell me it is impossible, so that I will just wait until Autodesk opens up the API…)
Keynote Tag Placer - Copy Method.dyn (19.2 KB)
Did you ever find a solution? I was thinking of making a wall tag and then pulling information from the element of the keynote to the tag by a shared parameter. Just not sure thats possible. The other way would be to grab the element keynote value and put it into a tag value but this would be risky in the long run
I tried this without luck. Exact same technique and still it becomes a question mark “?”… What you can do instead is read keynotes and create a text on top of the elements and replace texts with the keynote values.
