I am trying to make a script which would place family instances on face and in specific heights in the wall… I managed to set this up correctly but only thing that is not working seems to be the hosting…
The element is hosted when you click on it, also the schedule level is set but visually it still doesnt seem right (the void is not cutting the concrete), in the picture you can see the family below placed by the script and above is the instance placed manually… is there anything else I can do to make it work properly?
I found out that if I manually change the schedule level for the instance placed by the script it then starts looking the same as the instance placed manually (it cuts the concrete)
