Placing existing views on existing sheets
Hi Everyone,
I was looking for a way to place existing views on existing sheets and I found the post below by @Joseph_Peel about separating a Python script for creating new views and placing them on new sheets in two.
I am trying to use the second python script to put my existing views on existing sheets, But I am confused about the inputs of the script. What should I use for IN[0] and [1]. Now I am using the element IDs of the sheet and view as inputs but this is the warning I get:
File “”, line 31, in
AttributeError: ‘str’ object has no attribute ‘Id’
Thanks A lot! :slight_smile:
Hello @bzolghadri!
I tried to create this as well to help you out and what I found was that the code works when it’s pulling from a categories list as opposed to individually specified elements see attached for how to layout the node and how to setup the script. Hope this helps!
Views_On_Sheets.dyn (8.0 KB)
Thank you Nick!
As you mentioned, I have to have a list of Sheets and Views to make this node work.
I am now experimenting ways to come up with a way to filter my Sheet list and View list.
Can you post the custom node for “View On Sheet”?
Hi John. The custom node is attached.
View On Sheet.dyf (4.8 KB)
Hi @bzolghadri
Have you had any luck with figuring this out? I’ve been trying to achieve the same outcome. I’ve merged your node with one from @Daniel_Woodcock1’s script that places legends on sheets.
How would I match the view names (or a part of the name) with the sheet name or room number and place them on the corresponding sheet? I have seen several workflows that do this from an excel file, but all my content is already in Revit.
SJ_ViewPlacerWIP.dyn (30.5 KB)
