I am trying to create sheets (hundreds) with a specific set of views on each sheet. I have 225 3d views, 225 section views, and 225 floorplan views (actually just top-down section views) and I am searching for a way to put 1 of each of those types of views on each specific sheet. In the end, there should be 1 3d, 1 section, and 1 floor plan view all on a sheet together. I have been trying a few things but I cannot seem to find a way to pull 1 of each type of view individually to make a sheet, and I also have no idea how the titleBlockFamillySymbol input works.
So we have 4 lsit: 1 for list sheet, 1 for 3d view, 1 for section, 1 for floor view. just use method Viewport.Create() method and use function for in python.
ex: For i in 3dlist:
Viewport.Create(i,…) : need take 3 arguments
and continue with section and floor view. And you will get each view and input in each sheet.
Update: I converted my sheet numbers to strings within the python script. Sorry about the post. Been trying for a few weeks and the light bulb went one about 5 minutes after this post.
Hi Guys, I have tried several Python Script nodes for creating sheets, and I keep receiving the following error on the Viewsheet.Create line: Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. Traceback (most recent call last): File “”, line 30, in AttributeError: ‘int’ object has no attribute 'Id I have read about this error, but do not understand how x=Viewsheet.Create(y,z) is an integer? Do you know what is going wrong? Thanks, D
I am pretty new to dynamo. I am trying to use the second python script to put my existing views on existing sheets, But I am confused about the inputs of the script. What should I use for IN[0] and [1]. Now I am using the element IDs of the sheet and view as inputs but this is the warning I get:
File “”, line 31, in
AttributeError: ‘str’ object has no attribute ‘Id’
These need to be lists of the actual sheet and view elements. So if you have IDs use Get Element By ID and then feed the elements into the python node.
