OK…let’s say we have a hypothetical wall assembly built with 4 layers of 1/2" plywood on the exterior side, a core layer made of 5 1/2" wood studs, and a layer of 5/8" gypsum board on the interior side. The total wall thickness is 8 1/8". I would like to place / create a line at the centerline of the core layer…the 5 1/2" stud layer. Is this possible with Dynamo? My google search over the last week has not produced the desired result. I’ve learned other things along the way, but I feel as though there is an easy solution to my problem that I may simply be over-looking. Thoughts and/or comments?
Related topics
| Location of wall's center of corecenter line | 10 | 5253 | February 12, 2019 | |
| Draw Detail Lines of Core Wall from Complex Walls from Linked Model | 7 | 1160 | August 22, 2019 | |
| Identifying the wall layers and get a centerline of core of the wall | 2 | 1602 | February 4, 2019 | |
| How can I get the center line of the core of a wall on Dynamo? | 3 | 1206 | February 12, 2020 | |
| Wall Center Lines with Dynamo | 8 | 6558 | June 13, 2023 |
