Place stairpaths
I am struggling for a while with these stairpaths, so hopefully someone can help me. In every view we have to tag the stair with a stairpath to show the direction of it. In Dynamo i did not find a way with the available Nodes. Maybe one of you can help me. iI should be something like:
  • Get all stairs in Active view
  • tag these stairs with a stair path
Kind regards
See this for a start:
Thanx for the reply.
Actually this stair path annotation reads the stair path line in the sketch of the stair
and tags this with an up/down arrow. The annotation will be auto-placed on the same line of the sketch.
Could you attach a screenshot of your graph?
There is a stair path creation method in the Revit API, so something should be doable:
http://www.revitapidocs.com/2017/86f6b092-6023-d978-b552-34e0e8f3444d.htm
For people who are interested in this script to automate placing stairpaths in view:
Create Stair Paths by View.dyn (9.1 KB)
for stair in stairs:
	stairid = LinkElementId(stair.Id)
	newpath = Autodesk.Revit.DB.Architecture.StairsPath.Create(doc, stairid, pathid, doc.ActiveView.Id)
	newpaths.append(newpath)
