I am trying to revise the script that creates stair paths, which I found here:
but it’s really not my forte…
I have added another input IN[1], for the views to process. (line 27).
I have two questions:
- if I feed only one stair to the script, I get an error, because they need to be a list. How do I also allow single elements, for both stairs and views?
- Input IN[1] is the list of views. I doubled the “for” loop, adding a loop for the views, in line 49, however, I don’t know how to get the view ID (line 51)…
I am getting this error:
Here is the (badly) revised script:
#Import DocumentManager
#Import RevitAPI
clr.AddReference("RevitAPI")
#Import ToDSType(bool) extension method
from Autodesk.Revit.Creation import *
stairs = UnwrapElement(IN[0])
views = IN[1]
typelist = list()
newpaths = list()
#find stairpathtype
collpathtype = FilteredElementCollector(doc)
filtpathtype = ElementCategoryFilter(BuiltInCategory.OST_StairsPaths)
stairpathtypes = collpathtype.WherePasses(filtpathtype).ToElements()
for stairpathtype in stairpathtypes:
istype = stairpathtype.ToString()
if istype == "Autodesk.Revit.DB.Architecture.StairsPathType":
typelist.append(stairpathtype)
stairpathtype = typelist[0]
pathid = stairpathtype.Id
#create stair path for stair runs
for view in views:
for stair in stairs:
stairid = LinkElementId(stair.Id)
newpath = Autodesk.Revit.DB.Architecture.StairsPath.Create(doc, stairid, pathid, view.ViewId)
newpaths.append(newpath)
doc.Regenerate()
uidoc.RefreshActiveView()
OUT = newpaths
Thank you
reagrds
gio
