Place points with dynamo in a generic model family
I’am trying to place points in an adaptive generic model family but the points appears just in dynamo, not in the revit family and I don’t know why.
I share the script and the excel
Can someone help me ?
Importation points.dyn (21.3 KB)
points chaussee.xlsx (14.8 KB)
Hi @andre.micka
you can use the below code
the code must be run in adaptive family environment
these two line if you need points to be adaptive
		AdaptiveComponentFamilyUtils.MakeAdaptivePoint(doc, p.Id, AdaptivePointType.PlacementPoint)
		p.CoordinatePlaneVisibility = CoordinatePlaneVisibility.Always
# Enable Python support and load DesignScript library
clr.AddReference('RevitAPI')
app = doc.Application
X=IN[0]
Y=IN[1]
Z=IN[2]
t = Transaction(doc, 'create a single reference point')
t.Start()
#define x, y, and z variables
j=0
for  item in X:
		x=X[j]
		y=Y[j]
		z=Z[j]
		myXYZ = XYZ(x,y,z)
		p = doc.FamilyCreate.NewReferencePoint(myXYZ)
		j=j+1
#declare a XYZ variable
#use XYZ to define a reference point
t.Commit()
# Place your code below this line
OUT = 0
This might also help: Dynamo Dictionary
