Archi-Lab Change Family Type Issue
Hi all,
This script is not working for me, does it look correct?
It’s really an old node that I had in there. Try this instead and i will update that stuff at some point:
# Copyright(c) 2016, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
    return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessParallelLists(_func, *lists):
	return map( lambda *xs: ProcessParallelLists(_func, *xs) if all(type(x) is list for x in xs) else _func(*xs), *lists )
def ProcessListArg(_func, _list, _arg):
    return map( lambda x: ProcessListArg(_func, x, _arg) if type(x)==list else _func(x, _arg), _list )
def Unwrap(item):
	return UnwrapElement(item)
def ChangeType(element, typeId):
	element.ChangeTypeId(ElementId(typeId))
	return element
if isinstance(IN[0], list):
	elements = ProcessList(Unwrap, IN[0])
	elements = [Unwrap(IN[0])]
typeIds = IN[1]
try:
	errorReport = None
	if isinstance(typeIds, list):
		output = ProcessParallelLists(ChangeType, elements, typeIds)
		output = ProcessListArg(ChangeType, elements, typeIds)
except:
	# if error accurs anywhere in the process catch it
	import traceback
	errorReport = traceback.format_exc()
# End Transaction
#Assign your output to the OUT variable
if errorReport == None:
	OUT = output
	OUT = errorReport
Cheers!
Many thanks
