Place object faces on Draft view and group the normals
I have a plank. I want to split it into faces and group them by their normals directions in a way that opposite normals also get grouped together. (Up/down get grouped together, left/right, back/fourth).
After that I want to take first item from all 3 groups and place as detail drawings on draft view.
That should end up with 3 detail sketches on a drafting view
How do I do that?
Curious… Drafting views are a bad idea for object representation as they don’t hold any relationship to the model once they are created, while model views would. Why not use model views?
Tried this as a workaround for detailing since couldn’t figure out how to rotate section in dynamo. Wasn’t a good idea. As you mentioned it needs to be updated all the time to match the model as well as it being it’s own challenge to pull off.
This can be a quite difficult topic… We did cover it in this Dynamo Office Hour, so hopefully you can identify the content from there.
