Hello, I’ve recently started to work with Dynamo and I have the following problem:
I have a list of views. Per view I want to place a single detail item at a given point also from a list. I just can’t get it to work. It only works when I take the first item of the view list, but then it places all the detail items in this first view. Am I doing something wrong or this this simply not possible ?
In your initial version (not for one element), try using views and points at level 1 and 2 respectively. If that doesn’t work try level 1 at both sets.
Sri g type of level - go back to how it was before but enable list levels in the FamilyInstance.ByPointInView.
Look here:
Also you should review the Dynamo Primer in its entirety. Skip nothing, even if the intended result feels like something you won’t use - the concepts demonstrated are the important bit, not the outcomes.
