Hi Dynamo community,
I am trying to place filled regions on a sheet (legend) but I have no clue unfortunatelly.
Any Ideas?
Thanks in Advance!
The Skript:
The Legend:
Place Filled Region Type.dyn (5.6 KB)
Any Ideas?
Thanks in Advance!
The Skript:
What does the error says?
I think its because of circle. Try converting circle to curve using Curve.Approximatewith Arc (Haven’t tried with circle though)
Mmm… Try creating rectangle shape model lines and extract curves and then join the curves with polycurve.byjoinedcurves node. See if that works!
@igpema Make sure you convert polycurve to curves. I have tested one and it works as expected.
@Michael_Waring @igpema Try using Python then FilledRegion.dyn (5.7 KB)
Oh yeah Kulkul,
great job! it works!
@Kulkul
Could you please paste the code also? Thanks
Hi @Yna_Db
I have already pasted the whole dyn script on top may be you haven’t seen that.
I prefer to avoid downloading files if you don’t mind, and I am sure that pasting the code it useful to any discussion about it if needed.
Hello Kulkul or Dyn. Community,
Unfortunatelly I still can not write with Python (I start a 6 months course in two weeks
But due to this fact, I am stuck on the issue that I want to apply more filled region types to the script, but the Python node doesnt allow it.
How could it be possible?
what I want:
Please paste your code and try to identify the part you would need to modify. You can do it this way:
See this optionally:
Thank you for this nice *.dyn.
I change it a little bit for us to place all FilledRegionTypes in a Drafting View.
Next Steps could be, tag them with Type-Name and how many Elements in project. But this next time
Place all FilledRegionTypes in File on a DraftingView_variabel.dyn (37.3 KB)
