Place detail item family by curve in drafting view
Hi
All the nodes I can find to place a family by line require to input a level.
Is there a way to place a detail item family by line in a drafting view (no level)?
Thnaks!
In the API Docs:
This overload applies only to 2D family line based detail symbols. The type/symbol that is used must be loaded into the document before this method is called. Families and their symbols can be loaded using the Document.LoadFamily or Document.LoadFamilySymbol methods.
http://www.revitapidocs.com/2018.1/899076fd-73d2-5be0-8872-b8f389d4ba49.htm
document.Create.NewFamilyInstance(line,famtype,view)
I’ve modified the code in FamilyInstance.ByPointInView node to make it line based but got the error “TypeError: expected XYZ, got Line” in this line:
newobj = doc.Create.NewFamilyInstance(line,famtype,view)
clr.AddReference('RevitAPI')
lines = UnwrapElement(IN[0])
famtype = UnwrapElement(IN[1])
view = UnwrapElement(IN[2])
elementlist = list()
counter = 0
# make sure familysymbol is active
if famtype.IsActive == False:
	famtype.Activate()
	doc.Regenerate()
for line in lines:
	elementlist.append(newobj.ToDSType(False))
OUT = elementlist
Please anybody can help?
Clockwork has a DetailComponent.ByCurve node.
Thanks man, worked like a charm and helped me to fix the Python code, just needed to convert Dynamo lines to Revit lines :slight_smile: :
newobj = doc.Create.NewFamilyInstance(line .ToRevitType() ,famtype,view)
