Hello
I am working on a graph to read data from excel, create new family types and populate family type parameters. Which I’ve got fine.
Next I want to layout an instance of the new families inside a drafting view. This is where I get stuck.
FamilIy0nstance.ByPointInView will not accept lists. Hence I’m trying to use list.Map to map the fuction.
If I use Point.ByCooridante(0,0,0) I get one instance of each family at (0,0,0).
I tried to make a list of points to feed as per graph below.
But this makes 4 instances in each of the locations.
Can someone help me with how to set these out… Ideally I’d like these to stack vertically depending on the size of each.
